I am new to grafana. Is hierarchy or drilldown is there in grafana.
@asuryasudheer cna you please expand here? Can you include screenshots? What are you trying to achieve? There is a filter feature for table columns that you can use to drill down on specific rows…
We tried in Grafana normal level. Is it possible in Enterprise level as it is having reporting.
Drilldown means it will open another window. I want as shown below in the same window
Please find the below image
When you click on Image1 as shown above
It will expand as shown below in image2
If you further click city as in image2
It will display the data as in image 3 as shown below
Ok, @asuryasudheer I think I understand. You cannot nest rows inside rows in a hierarchy like you are visualizing. Not in the table panel, as far as I know. I think the closest thing to this functionality are expanding and collapsing panel rows.
This might make a great enhancement request in the repo!
How to expand or collapse the panel rows. Can you please explain in detail
Here is a good tutorial on dynamic and repeating rows:
It’s not possible, I’m asking for this the last 2 years.
It would even be the reason to buy the enterprise solution for me.
did you make a feature request?
How? and where?
I was expecting this would be the request actually.
I’d check here to make sure this doesn’t exist already, and then start a “discussion” if it doesn’t. Those with lots of upvotes are more likely to get traction.
Hey,
Please help to configure Grafana dashboard with nested variable to proper save data to corresponding fields(keys/values). my data is in .json format.
- In header it has value of jenkins job date and sub headers are: hits, total, coverage columns.
- Three rows merged and named as projects/repo then each three rows have named: lines, functions, branches.
My concern is that data is not getting properly fitted in rows/columns project wise/date wise.
Shared the screen shot of table which is in html format and I want to see a similar kind of format or implement filters to show the correct data in table in Grafana dashboard.
