How to create a pop-up when I click any data in a panel?
Hey All !
I’m using the Grafana cloud, and I am trying to implement a pop-up using the HTML Graphics visualization. The pop-up will be displayed when the stat inside another Grafana panel is clicked.
I tried the conventional implementation of the pop-up, but looks like Grafana doesn’t allow pop-ups, so I would like to know if this is even possible in Grafana or not. If yes, how can this be implemented?
Thanks!
