Hi there,
I’m a beginner here, you will find below the details.
Thank you for your help.
v8.0.3 on Chrome -
A pie chart representation -
From a Postgresl table.
The table view look like this :
Date | Modality | sum_modality
2021-09-02 | AC | 4
2021-09-02 | AB | 3
2021-09-02 | CA | 3
2021-09-01 | CA | 2
2021-09-01 | BG | 6
2021-08-31 | BG | 3
2021-08-31 | AC | 3
What happened?
Didn’t achieve to well set up the pie chart to display the distribution with a filter per date. -
I would like to display the distribution in pourcent. For exemple if I choose to filter only on this date ‘2021_09-02’, the pie chart is suppose to show 25% AC, 33,3%, AB 33,3% CA.
And if I choose to filter on several date, rates should be automaticly update.
- Can you copy/paste the configuration(s) that you are having problems with?
select
$__timeGroup(date, 1d),
modality,
sum(count_modality) as sum_modality
from
schema.table
GROUP BY
date,
modality,
count_modality
no -
Didn’t find relevant instructions
