Not able to Visualize in Pie chart using Grafana Dashboard and plugin as CSV
|CREATED_DATE|ID|STATUS|ID_TYPE|
|12-Apr-24|5-123456|Order Placed|Order|
|14-Apr-24|5-999999|Order Placed|Quote|
|14-Apr-24|1-13EJPU9|Converted|Lead|
|14-Apr-24|1-037733|Order Placed|Quote|
what are you expecting the pie chart to look like?
It should appear like this
@vijaydaresforyou on Grafana Play you can see examples of how pie charts are done, I recommend specifically looking at how the data is formatted that goes into them
https://play.grafana.org/d/ktMs4D6Mk/5-bar-charts-and-pie-charts?orgId=1&tab=query
You’re looking for pie charts that display numbers and relative percentage distribution, but that is not in your input data, which is just a list of orders that were placed. To make these pie charts, you’re going to need to aggregate your data into a set of counts. It looks like you’ve got pipe delimited text data, so what you might do is aggregate by ID_TYPE counts of the number of records you’ve got, and then put that data into a pie chart.
This can be done by investigating transformations in Grafana
Thanks Davidallen5, this is the data I am trying to Visualize.
CREATED_DATE ID STATUS ID_TYPE
12-Apr-24 5-6373373 Order Placed Order
14-Apr-24 5-467274 Order Placed Quote
14-Apr-24 1-16EJPU5 Converted Lead
Thanks, how can we have multiple graphs in visualization as I have requested.
you create distinct panels within the dashboard
Thanks Yosiaz, how can we have distinct panel within the dashboard.
Then change each panel’s query
