Hello. Im currently using Grafana 10.4 in a local PC and connecting to it through a static IP and the browser. -
Im trying to create a pie chart with the % of the total represented by the different robot types from a logs database (ElasticSearch).
I’m selecting the pie chart visualization. Then, at the value options drop-down, I select “Count” as Calculation function and “family” as selected field (Family represents the type of robot)
What happened?
The pie chart is not showed and the legend only shows “family” instead of the different types of families
I expected something like “50% toaster, 30% printer and 20% painter”
Can someone help me solve this? Thanks!
