Grafana Pie Chart usage
I am new using Grafana. I need to create a pie chart in Grafana from a postgreSQL datasource.
My table has the structure (time, user, count), and I would like to represent the maximum number of count per user, so I would need to have one section of the pie per user. Is that possible?
I have already read this topic regarding the pie chart:
but I couldn’t manage to get the desired result.
I have tried:
SELECT
now() as time,
MAX(count)
FROM
shema.table
GROUP BY user
But I only get all the pie in the same section with the value of the max count for all user, not the maximum per user.
Thanks in advance!! :slight_smile:
Hi Dharma77,
This is related with postgres, not to grafana.
Can solved it in the following way:
SELECT
now() as time,
MAX(count) as value,
user as metric
FROM
shema.table
GROUP BY user
Thanks! Problem solved :smiley:
Hello, I have some problems with the pie chart. I use v7.5.5, and then use the following statements:
SELECT
  now() as time,
  principal as metric,
  count(1)  as value
FROM jhi_persistent_audit_event
GROUP BY principal
The results are as follows:
The tag name of the pie chart I want to display is the value of metric, such as admin, but the tag name it displays is not what I want to display. As shown in the figure below:
What did I do wrong?How can I modify it
What grafana version are you using?
The version I used was 7.5.5, and I later tried to use 8.0.2, but the new version didn’t have this problem
Hey!
how do I create the pie chart without using now() as time.
I have a timestamp field which I want to use as time.
For eg if the value in timestamp field is 5/11/2021 it should count the values ahead of the date 5/11/2021.
