my jsonapi was like this:
"code": 200,
"status": "success",
"data": [
"metric": "ping_new_lvs_scores",
"UpdateTime": "2024-10-10T23:18:54+08:00"
"metric": "node.bw.sw.pct",
"UpdateTime": "2024-10-10T23:12:05+08:00"
"errorType": "",
"error": ""
i can use jsonata:
$.data{$substringBefore(metric,' '): metric[]} ~> $each(function($v, $k) {
"timestamp":"2024-01-01 00:00:00",
"metric": $k,
"count": $count($v.{"code": $})
to got:
"timestamp": "2024-01-01 00:00:00",
"count": 1
"count": 2
but in grafana,i got two [object Object], i want create a pie chart and a time series chart, how can i do that?
i have set this
but i still got two object in table view
and no date in pie chart
my grafana version is 8.4.6,is that the reason?
i used the transformations to convert the fields to time and numeric as well
walkerxk:
"code": 200,
"data": [
"errorType": "",
"error": ""
i can only convert result to time
when i want to get metric, i got two objects.
where is the metric value (count) in the latest payload?
walkerxk:
"count": 1
"count": 2
i can create pie chart using infinity datasource, so may be it is the promblem of jsonapi datasource?but in infinity i can’t count metric.
my source data is as follows:
"code": 200,
"data": [
"errorType": "",
"error": ""
if i use this in infinity, i got one ping_new_lvs_scores one node.bw.sw.pct one node.bw.sw.pct
i want got one ping_new_lvs_scores and two node.bw.sw.pct. in json api datasource, i use jsonata to do the count job, but infinity didn’t support the count function.
thank you very much, it seems that i use group by in a wrong way, it is ok now.
