I’m using a JSON API datasource plugin to query a REST API to populate some metrics.
I’m not able to structure the JSON response for the timeseries graph plugin.
Can I get some help with this?
Grafana v7.5.7 (91de51771c) & Ubuntu 18.04 -
Generate timeseries graph using JSON response data obtained from REST API
Need help in structuring the JSON response to generate the timeseries graph. -
Using JSON API datasource plugin & querying my REST API endpoint to get data. -
What happened?
Graphs are not being populated. -
Graphs to be populated -
No errors found. -
No instructions for this.
