I am running Grafana v11.4.0 (b58701869e)
- What are you trying to achieve?
I have data in the form
dateString | sgv
2025-01-02 13:28:36 | 90
2025-01-02 13:28:40 | 67
2025-01-02 13:28:50 | 110
2025-01-02 13:28:56 | 190
and I would like to have a visualization, e.g. a pie chart to show me the percentage of the values below a given minValue = 70, above maxValue = 180 or in between those?
I think it should be possible to achieve this using Transformations, but I struggle to understand how to get there. I know how to filter the entire dataset but I have not yet managed to filter it to get the pie chart to work.
Which transformations would I have to apply to get there?
What is your datasource? An api or a database?
I am using GitHub - haohanyang/mongodb-datasource: MongoDB data source for Grafana as data source. I have seen some resources on how to aggregate the data from flux but not that many on the transformation side.
I highly recommend you try to do it in Mongo’s query first, transformation as last resort
I found something like this - maybe it’ll help with the aggregation?
Using the following (I have to admit, ChatGPT result) it works. Thanks @yosiasz for the suggestion.
"$match": {
"date": {
"$gt": {
"$numberLong": "$__from"
"$lt": {
"$numberLong": "$__to"
"$group": {
"_id": null,
"below": {
"$sum": {
"$cond": [
{ "$lt": ["$sgv", 70] },
1,
0
"between": {
"$sum": {
"$cond": [
{ "$and": [
{ "$gte": ["$sgv", 70] },
{ "$lte": ["$sgv", 180] }
1,
0
"above": {
"$sum": {
"$cond": [
{ "$gt": ["$sgv", 180] },
1,
0
"$project": {
"_id": 0,
"below": 1,
"between": 1,
"above": 1
