How to change the option value for each query in table panel?
    Grafana v10.2.7
    Change the option name in table panel.
    Don’t know.
  • What happened?
Hello, I am using Grafana v10.2.7. I create a table panel, and create two query with sqlite database. In the option bar, their names have all been changed to attribute names. May I ask if I can change the names in the option bar myself? How could i make it?
What you call the option bar, is just a select bar.
And it shows always the coloumn names.
If you have got two times the same query, I would choose the Business Table Plugin.
Therein you can have tabs to handle the two results.
And you can name the tabs as you want.
Jo
