What Grafana version and what operating system are you using? = 8.1
What are you trying to achieve? =>
I’m adding a new panel to existing dashboard. I need a table to change it’s value based on dropdown value. -
I added a table panel. I’ve added 4 queries. Those are displayed as a dropdown values, just below the table. -
What happened?
Everything works as expected. But display wise dropdown values are all the column names from query & I cannot see any way to customize it. E.g. Instead of “A,Customer Name, App Version, …” it should show only “A” -
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. => No Error
Did you follow any online instructions? If so, what is the URL? => Didn’t get any details there as well.
