I’m using Grafana v8.0.6.
I made two queries, each one looking for different data.
I would like to rename the dropdown selection to a specific name.
How can I do this?
Current name is results.
How can I do this?
rename your query selection
ft.val AS "This is a new field name"
then the dropdown will show “this is a new field name”
Is it 2 columns from the same table you’re wanting to swap between?
Make a variable at the top called Result,
List the column names like “Col1,Col2,Col3”
Call it in your Query as
Select ft.Tagname
, ft.Timezone as Tempo
, $Result as ‘Valor’
From …
Can you show me how?
Here’s the Doc regarding Variables
Add a query variable | Grafana Labs
So you’ll add them as Custom and List the columns like “[Col1],[Col2],[Col3]”
Then add it to the Query
