Put Query Variable Dropdown into Panel Title
Hi so I’m new to the Grafana community and the application in general. I noticed that you can use a query variable name in the title by using $variablename. I was wondering if there was a way to access the same variable dropdown that’s in the dashboard but put it inside a panel’s title instead using some similar command in the panel title?
Thanks.
I guess my big question is: Is there a way to change what query variable value we’re using in the cycle view mode where we can’t see the dropdown?
Hi @shres and welcome to the Grafana forum.
Unfortunately no. But you can vote it up and/or add your feedback in either of the links below:
and
