is it possible to use variables (maybe the wording is wrong) from my query as panel title?
My datasource is CheckMK. Looks like this:
From the example above I would like to use the data which is stored in Graph Settings >> Service field. Or the data which is in General Settings >> Host.
Regards
Sebastian
This should certainly be possible, if I understand correctly. Here is an example on our public sandbox instance. You will need to set a template variable based on a query, and then you can add variable foo as $foo in the Panel title:
https://play.grafana.org/d/000000056/templated-dynamic-dashboard?orgId=1&var-app=country&var-server=IE&var-server=ZA&var-interval=1h
Thanks for your answer. But I really don’t know how to implement this… maybe its just not the solution to my problem
What I want to do is: In my case I want to use the selected service as title.
(In this case should the term “CPU load” be the title.)
Ah, ok, I understand.
I’m guessing that you are using this plugin?
if so, that’s a community built plugin. It looks like you want to use the value chosen in that select box as a template variable. This is probably achievable with a query-based template variable.
I would make an issue or ask for help in that plugin repo. They will have the expertise to get you unblocked here
Yes you’re right. Will try this way.
Thanks for your help!
