How to use query variables in panels / metric queries
    Rocky Linux 9, grafana-10.1.4-1.x86_64
    It is hard for me to understand the basic concept behind variables (I guess).
    I have a prometheus datasource with several jobs monitoring website endpoints.
    I would like to automatically create panels on a grafana dashboards (one panel for each monitored site) via “repeat”.
    So I created a query variable on a grafana dashboard which contains all instance names:
I see the required values on the bottom of this page:
So I try to use this variable now to create a dashboard panel in the filter. You can see the variable contains the desired value in the panel name:
But it says “No data”.
If I put the name to the filter statically, it gets the data:
But I want to use the variable in order to be able to dynamically use the dashboards / repeat panels.
I just discovered it works when disabling the multi value or all option in the variable settings. But I would like to be able to choose more than one variable at once to repeat the panel automatically. The repetition works as expected, but as said without data:
What am I doing wrong? How can I achieve my goal?
I am aware this must be a pretty basic question and I really tried to solve it myself via documentation, reading tutorials, and so on …
Welcome @lechuck to the Grafana forum.
Can you try changing the syntax to:
probe_success{instance=~"$query_sites"}
and see if that allows you to select multiple instances?
Source: Prometheus template variables | Grafana documentation
Thanks, but unfortunately this makes no difference. It still says “No data”.
Just to be sure: It does not even work when selecting only one specific query variable result, as soon as the “all” (or multi value) option is enabled for the variable.
