Changing data options naming in dropdown for a Table with multiple queries?
Grafana v7.5.6
Hello, Im hoping this is a simple question, very new to Grafana and still in a learning process with everything.
I have two mysql queries to build a table.
Only the dropdown to select either query in the table displays all the column names. I have looked and can’t seem to see a configuration for this. Can the name I have called this query be called instead?
Thank you!
You can use the transform function to deal this problem.
Would you know which transformation?
Could you done/achieve it? I want the same!
unfortunately not im afraid
I transform the name of column, but i only want to change the name on the dropdown not how it shows on the column of the table?
