Create tables in Grafana
I have been trying to use Grafana as our Infrastructure reporting tool which currently relies on some bash scripts to report the disk usage, number of CPU cores, memory etc. I have installed Grafana/Graphite and collectd agents in the servers and I am getting graphs. But, the reporting team is not happy with the graphs, instead they need a table in which it shows the server name, total disk usage, number of CPU and memory in different columns for each server.
Can this be achieved using Grafana/Graphite? Or should I use any other data source?
Kind Regards,
Tuxworm
Yes, there is a bulit in table panel
http://play.grafana.org/dashboard/db/table-panel-showcase?orgId=1
Thanks Torkel, I have created the table. Is it possible to rename the Metric and Current titles with different strings/names using the regex option in the table?
Cheers.
yes, this you can rename column headings using the column style rules
