I’m only checking these endpoints every hour or so, but still I’d like a joined line graph. What am I missing please?
Do you seen the Connect Null Values option in the right hand pane?
Connect Null Values = Never
Connect Null Values = Always
Thank you for your reply!
I’m using Grafana v8.1.1 (90c87a52f7) and I don’t see this right hand pane in the Explore menu. What am I missing?
When you select Edit on your panel, what do you see? Can you post a screenshot?
Also, no need to enter the Explore menu, as there is nothing there to help fix your issue.
Ok, I created a panel and then I could find that connect null values option.
THANK YOU!
