How can I set menu Items in app?
I’m developing an app plugin. Assuming the app is named “test app”, I want to build the nav menu as follows.
test app
  1. group
    1-1) Group Setting
    1-2) Group Tree
  2. Advice
    2-1) Advice Setting
    2-2) Advice View
If I want to add a Group menu and an Advice menu, do I need to develop two apps? Is there an easy way to build the menus?
hi @miraekim1031 what you want is the includes property in the plugin.json file (see this) you can see an example in our app example https://github.com/grafana/grafana-plugin-examples/tree/main/examples/app-basic
at the moment apps can not have sub-sub-menus (since the app itself is already a submenu)
When you land on “apps” for the first time, the landing page shows a square-shaped button with the app’s name and description. Can you explain how I can add such a square-shaped button on the landing page?
Same way I mentioned before. Using includes
What kind of property should I use? Thank you for your help.
