Grafana Custom App Sidebar customization
Hello.
I am trying to create a Grafana App (in React, if that helps).
What I want to achieve is to customize the sidemenu for each organization.
Example:
In the above figure, I would like to add or remove pages. I know that if they are included in the plugin.json file, in the includes section, I am able to configure which ones to show or hide. But this would cause them to be “grafana-wide” configuration.
const { path, onNavChanged, meta } = this.props;
    let tabs: NavModelItem[] = [];
     * Home
    tabs.push({
      text: 'Home',
      url: path,
      icon: 'fa fa-fw fa-home',
      active: true,
      text: 'Teste',
      url: 'someUrlHere',
      active: true
     * Header
    const node = {
      text: meta.name,
      img: meta.info.logos.large,
      subTitle: "Application",
      url: path,
      children: tabs,
     * Update the page header
    onNavChanged({
      node: node,
      main: node,
      breadcrumbs: tabs,
I tried this but anything done here didn’t reflect anywhere that I noticed, especially the sidemenu/NavBar.
How would I be able to customize the NavBar Section of my own app plugin?
Hi! I don’t believe it’s possible to programmatically manage items in the side menu. I’ll forward your feedback to the team to let them know you’d be interested in something like this.
That’s what I feared the most.
I will keep an eye on any grafana updates to see if this will be supported.
Thank you Marcus, appreciate your feedback.
