Can I create a mutiple app plugin in Grafana?
Hi, first of all Grafana is great and really easy to use,My questions is can i just create a app plugin in grafana,so if i want create more than one App Plugin,how can i do that?
@hakimanhqwe You can’t create multiple app plugins, but you can create as many plugins as you want. Put App plugins in separate folders inside plugins, and you are good to go.
Similar topic
