How can I change the threshold colors from config query?
Hi, I have an MSSQL query to load dynamically the threshold values, that is because I have a variable in the dashboard that changes the variable displayed, so I need to change the threshold depending on the variable, right now I can load the threshold values using the transformation type “Config from query results” but I can not assign the colors, I have tried with columns with the color names but nothing happened, so I want to know if someone has an idea about how to manipulate the threshold colors using the transformation “Config from query results”.
imagen
Right now I am getting each threshold value in a column, it works, but the colors are the problem, all of them are red and I want to assign a different color for the different thresholds.
grafana gauge 02
Just in case, I am using grafana version 8.1.2.0.
Thanks in advance for any help you can give me with this.
Hi @danielgnebackup
thanks for bringing this up. Fiddled with some examples for a few minutes but I’m blocked. This might need to get reported in the repo as a bug / enhancement
I’m trying to solve a similar problem, have you found any solution or has there been any development since?
Thanks
are there any updates on this problem?
Hello!
I’m really interested in this topic too but i cannot make it work with 8.2.2. Do we have any updates on this?
Thank you very much
Same here. Any news?
I have the same issue, my current version is 8.4.3. Any news about changing the threshold colours?
Desired outcome:
this only works when you configure the value mapping beforehand, there is no way to dynamically set the threshold.
