Grafana v10.4.2 on windows -
i have a time series of points that has dynamic thresholds and i want to change the colors according to the ths. the ths i get from a query. -
i tried many ways but because i can’t use variables on the th option i altered the query so for each point i get the color it suppose to have in color column. i used transformed data and choose Config from query results to set the color. -
What happened?
when i choose table instead of time series i get that the cell is colored in the right color (similar to this Grafana) but when i choose time series it shows all in single color but when i hover over a point it shows in the small window the right color -
i expected to see the points colored in the time series according to the values from the query -
Grafana
I don’t really understand what your problem is yet. Can you please show some sample data.
General tip: if you work with different threshold values and you want to express this in a colour, then you have to change the ‘Gradient mode’ to ‘Scheme’.
