v11.1.4 -
I have a line graph and a dynamic threshold, I want to have the line colored in red UNDER the threshold (and green when it’s over the threshold). -
I used “Config from Query” and defined the threshold. So far, so good.
Then I tried to change the threshold color, but that does not work as I thought, even when I modify the base color for threshold (right pane) -
What happened?
It only changes the color OVER the threshold, the color UNDER the threshold seems to be green by default.
I expected to be able to change the base color (ie UNDER the threshold) to a different color than green. -
I found a GitHub issue mentioning such a problem, but it was closed because it is supposed to work on v11. Am I missing something?
