The graph hover tooltip isn’t updating with the points I’m hovering over. This only happens when I choose “All Series” on Display → Hover Tooltip → Mode. I choose “Single” then it will work. Am I missing something or is this a bug?
I have exactly the same problem. Was there any solution for this issue?
So strange. Its working fine for me. Are you using grafana 6.6
