Hi when I try to see the different series in the graph, the last month appears in all the series
if you can help me i would apreciate so much
pd. i use grafana 7.1
pd2. i dont know if is a bug or something i do wrong
Please share with us the panel configuration, also if you suspect a bug, did you try on a more recent version ?
Good Luck
this is what i have in the axes’s category
this in the hover
and my query is simple
i cant use another version of grafana
thanks 4 the reply
