Grafana v7.5.5 (b5190ee547) on Debian 10 -
Display many (15-30) bar gauges horizontally with scrollbar
- How are you trying to achieve it?
Select visualization “bar gauge”, change orientation to “horizontal”
- What happened?
If the panel is large enough to fit all bars, all is fine, if panel is too small, gray scrollbar at the right is (partially) drawn over bar values.
bar values should be offset from right edge of panel to account for
n/a -
n/a -
n/a
possibly/slightly related to Bar Gauge panels - strange grey bar at right since 7.2.0 (Firefox Ubuntu) - #2 by codlord and/or Right side of bar gauges cut-off · Issue #27723 · grafana/grafana · GitHub
