Horizontal panel scroll bar mixed with dashboard's scroll bar
Grafana 7.0.1, latest
When i put the panel that has horizontal scrolling bar at the bottom of the dashboard, it is mixed with the dashboard scroll bar which makes it difficult to scroll the panel
Sorry the image is small, but it can be reproduced easily
Hello @trungld269, thank you very much for reporting the problem. Would you mind creating a github bug report issue for this?
