How do I make the scrollbar on Grafana table to be sticky?
I have around 15+ columns in a table in Grafana dashboard. I’m doing a “join by field” with Outer Join on a common field like time. The horizontal scrollbar is present but it only shows up when I hover over the panel. I want it to be more evident that there is a scroll bar without the need to hover over the panel.
Here’s an example on Grafana sandbox (though the columns here are much less and the size of the panel is much smaller but it still represents the issue that I’m trying to resolve):
Need the scrollbar to be shown without the need to hover over the panel
Using Grafana 11.3.1
