Debian 11
Grafana last version 9.1.2 -
Add the total of a column -
It already worked normally, after I migrated to version 9.1.1 there was a problem, I updated to version 9.1.2 and the problem continues. -
What happened?
As you scroll the table, the total menu scrolls along with the page -
The truth was as before, it was always fixed down.
normal
problem
