How to Fix a Column in Grafana Table Panel
Hi everyone,
I’m working with the table panel in Grafana, and I have a table with multiple columns. I’d like to fix or freeze a specific column so that it remains visible while scrolling horizontally through the table.
Is there a way to achieve this in Grafana? If so, could someone guide me on how to set it up?
Thank you in advance for your help!
you can’t freeze rows or columns
