Help with 'Fill below to'
Hi, I’m new here so bear with me.
I cant get ‘Fill below to’ working and wonder where im going wrong.
Im using InfluxDB to feed Grafana, its best if I post pictures to help show if I’m going wrong somewhere
Im trying to fill the area between the two graphs. After I select what I think is right in the ‘Series overrides’ section, I lose the display.
Any help would be appreciated.
Any ideas on the above, Im still trying various things but just not understanding why it’s not filling in the space between the upper and lower temperature with a color.
How about this? I did not play around with all the colors, gradients, etc. but maybe you can get it to look the way you are expecting.
BEFORE:
AFTER:
I tried but still failed to get the space filled
The lines disappeared and the space isn’t filled. Just confused as to why its not working, there must be a logical answer.
i have the same issue. sometimes i am able to enable it, but when saving the dashboard and reload it, both lines are there again (with filled areas). I’m on grafana 7.5.3
