Fill Below To - panel option
The new Grafana “Time Series” panel is missing the “Fill Below To” option. This option would fill a region between 2 lines.
Here’s what I mean as an example with the old “Graph” panel:
Is this possible with the new panel? I haven’t found an option that works, yet. Please let me know!
Ah, I realize it is (ONLY) in the overrides.
Unfortunately, you must specify an exact series name (regex does not work here) which means that the panel repeat options may not work the way you want them to:
