Hi, noob here.
I’m trying to use grafana (and influxdb) to show data from home assistant. Specifycally I’m drawing a graph of the actual temperature and the target temperature and this is fine.
Now I want to use a string field to change the area fill value so I can see when the heaters are actually on. Sadly I can’t find a way to do it.
I don’t even know the right lexicon to do proper searches.
Can you help me?
