I use Grafana 10.2.2 windows OSS build . Also i use an API call for heat map . Heat map will come correctly . I only get color mode scheme and opacity . Inside heat map no color will come . Please give me a solution .
I solved these . When i use a valid time series API call .Heat Map comes correctly.
