Grafana v11.0.1 on macOS Sonoma 14.6.1 -
To create an hourly heatmap. -
Using Marcus Olsson’s plugin. -
What happened?
It crashed. -
To render a heatmap. -
An unexpected error happened
Detalles
TypeError: Cannot read properties of undefined (reading 'pushEvent')
at o (http://localhost:3000/public/build/4570.662412df437585556b08.js:194:125072)
at div
at div
at S (http://localhost:3000/public/build/4570.662412df437585556b08.js:214:30537)
at Dt (http://localhost:3000/public/build/9569.5a70d677124a31e1b174.js:1:17609)
at Ot (http://localhost:3000/public/build/9569.5a70d677124a31e1b174.js:1:26310)
at Lt (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1013:7549)
at div
at div
at div
at d (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1055:100221)
at div
at div
at div
at o (http://localhost:3000/public/build/660.7a3e80ef7205ade8674f.js:1:2299)
at div
at o (http://localhost:3000/public/build/660.7a3e80ef7205ade8674f.js:1:4287)
at N (http://localhost:3000/public/build/660.7a3e80ef7205ade8674f.js:1:9622)
at div
at div
at div
at div
at div
at K (http://localhost:3000/public/build/4570.662412df437585556b08.js:357:21842)
at Un (http://localhost:3000/public/build/DashboardPageProxy.380854ed1827f82d8ad0.js:128:526)
at WithTheme(Connect(Un))
at or (http://localhost:3000/public/build/DashboardPageProxy.380854ed1827f82d8ad0.js:203:483)
at DashboardPage
at ir (http://localhost:3000/public/build/DashboardPageProxy.380854ed1827f82d8ad0.js:203:7030)
at Suspense
at kp (http://localhost:3000/public/build/4570.662412df437585556b08.js:5593:10782)
at Be (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1045:30572)
at er (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1036:4452)
at gs (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1036:12001)
at Dt (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1045:17388)
at Be (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1045:32722)
at main
at div
at div
at div
at Af (http://localhost:3000/public/build/4570.662412df437585556b08.js:5593:2412)
at div
at Ff (http://localhost:3000/public/build/4570.662412df437585556b08.js:5593:6738)
at ss (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1036:11337)
at ur (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1045:17687)
at Be (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1045:26763)
at h (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:120:8990)
at m (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1379:91286)
at i (http://localhost:3000/public/build/4570.662412df437585556b08.js:510:21356)
at m (http://localhost:3000/public/build/4570.662412df437585556b08.js:194:125581)
at nt (http://localhost:3000/public/build/9847.695cfbae7e9699f3f25f.js:1017:518)
at Yp (http://localhost:3000/public/build/4570.662412df437585556b08.js:5604:122)
- Did you follow any online instructions? If so, what is the URL?
