Hi, I have always successfully used the Carpet Plot Plugin in the Grafana 7.5 version. In Grafana version 10 it is deprecated and does not load.
Now I’m forced to use the Hourly Heatmap plugin. Unfortunately i have a problem.
if I select the “Custom” or “Field Options” value inside “Color Palette” section , i have unexpected error.
if i select “Spectral” or “RdYIGn” and other the plugin is ok.
Error details is:
.P.api is undefined
r@http://172.28.5.160:3000/public/build/5017.58916b80d8bde2b45aa3.js:194:122062
div
div
x@http://172.28.5.160:3000/public/build/5017.58916b80d8bde2b45aa3.js:214:30846
It@http://172.28.5.160:3000/public/build/9569.a8d60b39654a160cb917.js:1:17495
Ce@http://172.28.5.160:3000/public/build/9569.a8d60b39654a160cb917.js:1:26196
at@http://172.28.5.160:3000/public/build/5950.30ec6aaa9dcece6c3b3c.js:412:32691
div
div
div
b@http://172.28.5.160:3000/public/build/5950.30ec6aaa9dcece6c3b3c.js:454:101237
etc…
Does anyone have my mistake? can you to use the Hourly Heatmap plugin and change the Color Palette section?
Thanks
FRancesco
