Grafana v11.0.1 on macOS Sonoma 14.6.1 -
To create an hourly heatmap. -
Using Grafana’s built-in Heatmap visualization. -
What happened?
I don’t see the hours displayed on the Y-axis. I see the metrics instead. -
The days along the X-axis and the hours along the Y-axis, the buckets filled with colors depending on the metrics. -
if all else fails always check here
https://play.grafana.org/d/heatmap-calculate-log/grafana-heatmaps
