Hi! I need to have the same output I used to have in Grafana 9, now in Grafana 11, using Business Charts (Apache eCharts) from Volkov Labs…
Is there any appropriate example? Didn’t find anything similar in volkovs web page.
This is what I used to have:
Check the documentation, that is your help
Tried this code from the apache charts web page, but cannot make it work…
// prettier-ignore
const hours = [
'12a', '1a', '2a', '3a', '4a', '5a', '6a',
'7a', '8a', '9a', '10a', '11a',
'12p', '1p', '2p', '3p', '4p', '5p',
'6p', '7p', '8p', '9p', '10p', '11p'
// prettier-ignore
const days = [
'Saturday', 'Friday', 'Thursday',
'Wednesday', 'Tuesday', 'Monday', 'Sunday'
// prettier-ignore
const data = [[0, 0, 5], [0, 1, 1], [0, 2, 0], [0, 3, 0], [0, 4, 0], [0, 5, 0], [0, 6, 0], [0, 7, 0], [0, 8, 0], [0, 9, 0], [0, 10, 0], [0, 11, 2], [0, 12, 4], [0, 13, 1], [0, 14, 1], [0, 15, 3], [0, 16, 4], [0, 17, 6], [0, 18, 4], [0, 19, 4], [0, 20, 3], [0, 21, 3], [0, 22, 2], [0, 23, 5], [1, 0, 7], [1, 1, 0], [1, 2, 0], [1, 3, 0], [1, 4, 0], [1, 5, 0], [1, 6, 0], [1, 7, 0], [1, 8, 0], [1, 9, 0], [1, 10, 5], [1, 11, 2], [1, 12, 2], [1, 13, 6], [1, 14, 9], [1, 15, 11], [1, 16, 6], [1, 17, 7], [1, 18, 8], [1, 19, 12], [1, 20, 5], [1, 21, 5], [1, 22, 7], [1, 23, 2], [2, 0, 1], [2, 1, 1], [2, 2, 0], [2, 3, 0], [2, 4, 0], [2, 5, 0], [2, 6, 0], [2, 7, 0], [2, 8, 0], [2, 9, 0], [2, 10, 3], [2, 11, 2], [2, 12, 1], [2, 13, 9], [2, 14, 8], [2, 15, 10], [2, 16, 6], [2, 17, 5], [2, 18, 5], [2, 19, 5], [2, 20, 7], [2, 21, 4], [2, 22, 2], [2, 23, 4], [3, 0, 7], [3, 1, 3], [3, 2, 0], [3, 3, 0], [3, 4, 0], [3, 5, 0], [3, 6, 0], [3, 7, 0], [3, 8, 1], [3, 9, 0], [3, 10, 5], [3, 11, 4], [3, 12, 7], [3, 13, 14], [3, 14, 13], [3, 15, 12], [3, 16, 9], [3, 17, 5], [3, 18, 5], [3, 19, 10], [3, 20, 6], [3, 21, 4], [3, 22, 4], [3, 23, 1], [4, 0, 1], [4, 1, 3], [4, 2, 0], [4, 3, 0], [4, 4, 0], [4, 5, 1], [4, 6, 0], [4, 7, 0], [4, 8, 0], [4, 9, 2], [4, 10, 4], [4, 11, 4], [4, 12, 2], [4, 13, 4], [4, 14, 4], [4, 15, 14], [4, 16, 12], [4, 17, 1], [4, 18, 8], [4, 19, 5], [4, 20, 3], [4, 21, 7], [4, 22, 3], [4, 23, 0], [5, 0, 2], [5, 1, 1], [5, 2, 0], [5, 3, 3], [5, 4, 0], [5, 5, 0], [5, 6, 0], [5, 7, 0], [5, 8, 2], [5, 9, 0], [5, 10, 4], [5, 11, 1], [5, 12, 5], [5, 13, 10], [5, 14, 5], [5, 15, 7], [5, 16, 11], [5, 17, 6], [5, 18, 0], [5, 19, 5], [5, 20, 3], [5, 21, 4], [5, 22, 2], [5, 23, 0], [6, 0, 1], [6, 1, 0], [6, 2, 0], [6, 3, 0], [6, 4, 0], [6, 5, 0], [6, 6, 0], [6, 7, 0], [6, 8, 0], [6, 9, 0], [6, 10, 1], [6, 11, 0], [6, 12, 2], [6, 13, 1], [6, 14, 3], [6, 15, 4], [6, 16, 0], [6, 17, 0], [6, 18, 0], [6, 19, 0], [6, 20, 1], [6, 21, 2], [6, 22, 2], [6, 23, 6]]
.map(function (item) {
return [item[1], item[0], item[2] || '-'];
option = {
tooltip: {
position: 'top'
grid: {
height: '50%',
top: '10%'
xAxis: {
type: 'category',
data: hours,
splitArea: {
show: true
yAxis: {
type: 'category',
data: days,
splitArea: {
show: true
visualMap: {
min: 0,
max: 10,
calculable: true,
orient: 'horizontal',
left: 'center',
bottom: '15%'
series: [
type: 'heatmap',
data: data,
label: {
show: true
emphasis: {
itemStyle: {
shadowBlur: 10,
shadowColor: 'rgba(0, 0, 0, 0.5)'
which apache web page. did you read the one I posted?
Yes, thank you. I read it, but 'cause I’m looking for a heat map, I reached this: Examples - Apache ECharts
Thank you! I’ll try it out soon.
This works:
// prettier-ignore
const hours = [
'00hs', '01hs', '02hs', '03hs', '04hs', '05hs', '06hs',
'07hs', '08hs', '09hs', '10hs', '11hs',
'12hs', '13hs', '14hs', '15hs', '16hs', '17hs',
'18hs', '19hs', '20hs', '21hs', '22hs', '23hs'
// prettier-ignore
const days = [
'Sunday', 'Monday', 'Tuesday',
'Wednesday', 'Thursday', 'Friday', 'Saturday'
// prettier-ignore
return {
tooltip: {
position: 'top'
grid: {
height: '50%',
top: '10%'
xAxis: {
type: 'category',
data: hours,
splitArea: {
show: true
yAxis: {
type: 'category',
data: days,
splitArea: {
show: true
visualMap: {
min: 0,
max: 10,
calculable: true,
left: 'center',
bottom: '15%'
series: [
type: 'heatmap',
data: data,
label: {
show: true
emphasis: {
itemStyle: {
shadowBlur: 10,
But, when I tried to include this, it broke, even when I still didn’t use it:
const sData = context.panel.data.series.map((s) => {
const sDay = s.fields.find((f) => f.name === 'weekNumber').values.buffer;
const sTime = s.fields.find((f) => f.name === 'time').values.buffer;
const sAVRER = s.fields.find((f) => f.name === 'AverageBTsER').values.buffer;
return sTime.map((d, i) => [d, sDay[i], sAVRER[i]]);
And such data exists:
That was it! Omitting .buffer solved the problem!
Thank you!!
