Grouping values in Grafana chart results in duplicate ghost items
Can anyone describe why there are two hidden, duplicate items showing up on the chart?
Grafana v12.0.2 (5bda17e7c1) in Docker container
Get a single item on the chart for each of two different metrics, by aggregating the sum() of metric values, across multiple label values.
For an Access Point’s SNMP metrics, I am querying the inbound errors and outbound errors, as two metric queries. For each of the two counter metrics, I am using a Sum() aggregation to combine the values, across all Network Interfaces (eg. br0, ath0, eth0, wifi0, wifi1 etc.) into a single value.
What happened?
The chart is showing two different lines / colors, for each of the two metrics I’m querying. However, the duplicate items on the chart, don’t actually seem to have any values. There are two duplicate “ghost” items showing up in the chart.
The yellow and orange duplicate items are invisible, while the green and blue lines are actually visible and have values.
Each of the two metrics should have been aggregated into a single item on the chart.
  "request": {
    "url": "api/ds/query?ds_type=prometheus&requestId=SQR116",
    "method": "POST",
    "data": {
      "queries": [
          "refId": "A",
          "expr": "sum(rate(interface_InboundErrors{agent_host=\"10.0.0.45\"}[$__rate_interval]))",
          "range": true,
          "instant": false,
          "datasource": {
            "type": "prometheus",
            "uid": "ceqh1o5jdp8g0a"
          "editorMode": "builder",
          "legendFormat": "__auto",
          "useBackend": false,
          "disableTextWrap": false,
          "fullMetaSearch": false,
          "includeNullMetadata": true,
          "exemplar": false,
          "requestId": "4A",
          "utcOffsetSec": -21600,
          "scopes": [],
          "adhocFilters": [],
          "interval": "",
          "datasourceId": 2,
          "intervalMs": 15000,
          "maxDataPoints": 1386
          "refId": "A-Instant",
          "range": false,
          "instant": true,
          "datasource": {
          "exemplar": false,
          "requestId": "4A",
          "scopes": [],
          "adhocFilters": [],
          "interval": "",
          "datasourceId": 2,
          "refId": "B",
          "expr": "sum(rate(interface_OutboundErrors{agent_host=\"10.0.0.45\"}[$__rate_interval]))",
          "range": true,
          "instant": false,
          "key": "Q-2cd8320d-76e6-498f-a257-5fda32a81b69-1",
          "datasource": {
          "exemplar": false,
          "requestId": "4B",
          "scopes": [],
          "adhocFilters": [],
          "interval": "",
          "datasourceId": 2,
          "refId": "B-Instant",
          "range": false,
          "instant": true,
          "datasource": {
          "exemplar": false,
          "requestId": "4B",
          "scopes": [],
          "adhocFilters": [],
          "interval": "",
          "datasourceId": 2,
      "from": "1751433070386",
      "to": "1751436670386"
    "hideFromInspector": false
  "response": {
    "results": {
      "A": {
        "status": 200,
        "frames": [
            "schema": {
              "refId": "A",
              "meta": {
                "type": "timeseries-multi",
                "typeVersion": [
                  0,
                  1
                "custom": {
                  "resultType": "matrix"
                "notices": [
                    "severity": "warning",
                    "text": "PromQL info: metric might not be a counter, name does not end in _total/_sum/_count/_bucket: \"interface_InboundErrors\" (1:10)"
                "executedQueryString": "Expr: sum(rate(interface_InboundErrors{agent_host=\"10.0.0.45\"}[1m0s]))\nStep: 15s"
              "fields": [
                  "name": "Time",
                  "type": "time",
                  "typeInfo": {
                    "frame": "time.Time"
                  "config": {
                    "interval": 15000
                  "name": "Value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float64"
                  "labels": {},
                  "config": {
                    "displayNameFromDS": "sum(rate(interface_InboundErrors{agent_host=\"10.0.0.45\"}[1m0s]))"
            "data": {
              "values": [
                  1751434890000,
                  1751434905000,
                  1751434920000,
                  1751434935000,
                  1751434950000,
                  1751434965000,
                  1751434980000,
                  1751434995000,
                  1751435010000,
                  1751435025000,
                  1751435040000,
                  1751435055000,
                  1751435070000,
                  1751435085000,
                  1751435100000,
                  1751435115000,
                  1751435130000,
                  1751435145000,
                  1751435160000,
                  1751435175000,
                  1751435190000,
                  1751435205000,
                  1751435220000,
                  1751435235000,
                  1751435250000,
                  1751435265000,
                  1751435280000,
                  1751435295000,
                  1751435310000,
                  1751435325000,
                  1751435340000,
                  1751435355000,
                  1751435370000,
                  1751435385000,
                  1751435400000,
                  1751435415000,
                  1751435430000,
                  1751435445000,
                  1751435460000,
                  1751435475000,
                  1751435490000,
                  1751435505000,
                  1751435520000,
                  1751435535000,
                  1751435550000,
                  1751435565000,
                  1751435580000,
                  1751435595000,
                  1751435610000,
                  1751435625000,
                  1751435640000,
                  1751435655000,
                  1751435670000,
                  1751435685000,
                  1751435700000,
                  1751435715000,
                  1751435730000,
                  1751435745000,
                  1751435760000,
                  1751435775000,
                  1751435790000,
                  1751435805000,
                  1751435820000,
                  1751435835000,
                  1751435850000,
                  1751435865000,
                  1751435880000,
                  1751435895000,
                  1751435910000,
                  1751435925000,
                  1751435940000,
                  1751435955000,
                  1751435970000,
                  1751435985000,
                  1751436000000,
                  1751436015000,
                  1751436030000,
                  1751436045000,
                  1751436060000,
                  1751436075000,
                  1751436090000,
                  1751436105000,
                  1751436120000,
                  1751436135000,
                  1751436150000,
                  1751436165000,
                  1751436180000,
                  1751436195000,
                  1751436210000,
                  1751436225000,
                  1751436240000,
                  1751436255000,
                  1751436270000,
                  1751436285000,
                  1751436300000,
                  1751436315000,
                  1751436330000,
                  1751436345000,
                  1751436360000,
                  1751436375000,
                  1751436390000,
                  1751436405000,
                  1751436420000,
                  1751436435000,
                  1751436450000,
                  1751436465000,
                  1751436480000,
                  1751436495000,
                  1751436510000,
                  1751436525000,
                  1751436540000,
                  1751436555000,
                  1751436570000,
                  1751436585000,
                  1751436600000,
                  1751436615000,
                  1751436630000,
                  1751436645000,
                  1751436660000
                  39.01952,
                  74.36634,
                  94.66666666666666,
                  107.84444444444443,
                  86.79999999999998,
                  88.46666666666665,
                  70.33333333333331,
                  107.53333333333333,
                  109.15555555555554,
                  142.04444444444442,
                  119.39999999999999,
                  124.44444444444444,
                  92.19999999999999,
                  89.55555555555554,
                  80.17777777777776,
                  99.84444444444443,
                  91.08888888888889,
                  104.68888888888887,
                  89.17777777777776,
                  102.13333333333331,
                  81.3111111111111,
                  89.04444444444442,
                  76.77777777777777,
                  87.79999999999998,
                  86.02222222222221,
                  114.08888888888887,
                  99.79999999999998,
                  110.53333333333332,
                  82.28888888888888,
                  99.55555555555554,
                  79.66666666666666,
                  108.06666666666665,
                  97.1111111111111,
                  125.6222222222222,
                  97.08888888888887,
                  107.79999999999998,
                  90.6222222222222,
                  103.28888888888888,
                  90.57777777777777,
                  103.04444444444444,
                  90.35555555555554,
                  89.95555555555555,
                  67.44444444444443,
                  83.15555555555554,
                  79.22222222222221,
                  83.5111111111111,
                  69.13333333333333,
                  119.6222222222222,
                  122.77777777777776,
                  129.57777777777775,
                  82.33333333333333,
                  83.3111111111111,
                  72.97777777777777,
                  75.64444444444443,
                  61.35555555555555,
                  68.13333333333333,
                  61.66666666666666,
                  69.77777777777776,
                  61.133333333333326,
                  87.57777777777777,
                  93.3111111111111,
                  121.39999999999999,
                  113.37777777777777,
                  132.46666666666664,
                  113.71111111111111,
                  108.84444444444443,
                  79.73333333333332,
                  91.33333333333333,
                  80.22222222222221,
                  92.39999999999999,
                  75.37777777777777,
                  91.79999999999998,
                  84.15555555555554,
                  93.75555555555555,
                  76.84444444444443,
                  75.06333051864362,
                  59.22222222222222,
                  65.17053660704364,
                  58.55815814036179,
                  74.95555555555555,
                  70.87454161573507,
                  84.79999999999998,
                  69.4222222222222,
                  73.46666666666665,
                  61.199999999999996,
                  72.86666666666666,
                  67.17777777777778,
                  78.1111111111111,
                  63.377777777777766,
                  80.77777777777777,
                  66.24444444444444,
                  88.51111111111109,
                  71.3111111111111,
                  83.33333333333331,
                  66.22222222222221,
                  77.66666666666666,
                  65.57777777777777,
                  81.84444444444443,
                  68.46666666666667,
                  90.39999999999999,
                  70.33333333333331,
                  85.42222222222222,
                  62.79999999999999,
                  82.82222222222221,
                  64.91111111111111,
                  84.42222222222222,
                  71.06666666666665,
                  88.24444444444443,
                  67.93333333333332,
                  84.73333333333332,
                  65.53333333333332,
                  90,
                  65.04444444444444,
                  84.19999999999999,
                  61.04444444444444,
                  96.53333333333333,
                  89.35555555555554,
                  114.4222222222222,
                  80.3111111111111
        "refId": "A"
      "A-Instant": {
        "status": 200,
        "frames": [
            "schema": {
              "meta": {
                "type": "numeric-multi",
                "typeVersion": [
                  0,
                  1
                "custom": {
                  "resultType": "vector"
                "notices": [
              "fields": [
                  "name": "Time",
                  "type": "time",
                  "typeInfo": {
                  "config": {
                    "interval": 15000
                  "name": "Value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float64"
                  "labels": {},
                  "config": {
            "data": {
              "values": [
                  1751436670386
                  91.06666666666666
      "B": {
        "status": 200,
        "frames": [
            "schema": {
              "refId": "B",
              "meta": {
                "typeVersion": [
                  0,
                  1
                "custom": {
                "notices": [
                    "text": "PromQL info: metric might not be a counter, name does not end in _total/_sum/_count/_bucket: \"interface_OutboundErrors\" (1:10)"
                "executedQueryString": "Expr: sum(rate(interface_OutboundErrors{agent_host=\"10.0.0.45\"}[1m0s]))\nStep: 15s"
              "fields": [
                  "name": "Time",
                  "type": "time",
                  "typeInfo": {
                  "config": {
                    "interval": 15000
                  "name": "Value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float64"
                  "labels": {},
                  "config": {
                    "displayNameFromDS": "sum(rate(interface_OutboundErrors{agent_host=\"10.0.0.45\"}[1m0s]))"
            "data": {
              "values": [
                  1751434890000,
                  1751434905000,
                  1751434920000,
                  1751434935000,
                  1751434950000,
                  1751434965000,
                  1751434980000,
                  1751434995000,
                  1751435010000,
                  1751435025000,
                  1751435040000,
                  1751435055000,
                  1751435070000,
                  1751435085000,
                  1751435100000,
                  1751435115000,
                  1751435130000,
                  1751435145000,
                  1751435160000,
                  1751435175000,
                  1751435190000,
                  1751435205000,
                  1751435220000,
                  1751435235000,
                  1751435250000,
                  1751435265000,
                  1751435280000,
                  1751435295000,
                  1751435310000,
                  1751435325000,
                  1751435340000,
                  1751435355000,
                  1751435370000,
                  1751435385000,
                  1751435400000,
                  1751435415000,
                  1751435430000,
                  1751435445000,
                  1751435460000,
                  1751435475000,
                  1751435490000,
                  1751435505000,
                  1751435520000,
                  1751435535000,
                  1751435550000,
                  1751435565000,
                  1751435580000,
                  1751435595000,
                  1751435610000,
                  1751435625000,
                  1751435640000,
                  1751435655000,
                  1751435670000,
                  1751435685000,
                  1751435700000,
                  1751435715000,
                  1751435730000,
                  1751435745000,
                  1751435760000,
                  1751435775000,
                  1751435790000,
                  1751435805000,
                  1751435820000,
                  1751435835000,
                  1751435850000,
                  1751435865000,
                  1751435880000,
                  1751435895000,
                  1751435910000,
                  1751435925000,
                  1751435940000,
                  1751435955000,
                  1751435970000,
                  1751435985000,
                  1751436000000,
                  1751436015000,
                  1751436030000,
                  1751436045000,
                  1751436060000,
                  1751436075000,
                  1751436090000,
                  1751436105000,
                  1751436120000,
                  1751436135000,
                  1751436150000,
                  1751436165000,
                  1751436180000,
                  1751436195000,
                  1751436210000,
                  1751436225000,
                  1751436240000,
                  1751436255000,
                  1751436270000,
                  1751436285000,
                  1751436300000,
                  1751436315000,
                  1751436330000,
                  1751436345000,
                  1751436360000,
                  1751436375000,
                  1751436390000,
                  1751436405000,
                  1751436420000,
                  1751436435000,
                  1751436450000,
                  1751436465000,
                  1751436480000,
                  1751436495000,
                  1751436510000,
                  1751436525000,
                  1751436540000,
                  1751436555000,
                  1751436570000,
                  1751436585000,
                  1751436600000,
                  1751436615000,
                  1751436630000,
                  1751436645000,
                  1751436660000
                  0.13548444444444444,
                  0.22741999999999998,
                  0.22222222222222218,
                  0.1333333333333333,
                  0.39999999999999997,
                  0.6444444444444444,
                  0.7999999999999998,
                  1.0666666666666664,
                  1.1111111111111112,
                  0.6666666666666665,
                  0.2666666666666666,
                  0.31111111111111106,
                  0.37777777777777777,
                  0.28888888888888886,
                  0.3555555555555555,
                  0.5333333333333332,
                  0.6666666666666665,
                  0.6444444444444444,
                  0.6444444444444444,
                  0.5111111111111111,
                  2.1999999999999997,
                  2.133333333333333,
                  2.133333333333333,
                  0.4888888888888889,
                  0.42222222222222217,
                  0.3555555555555555,
                  0.6888888888888888,
                  0.5777777777777777,
                  0.6222222222222222,
                  0.33333333333333326,
                  0.17777777777777776,
                  0.19999999999999998,
                  0.15555555555555553,
                  0.2666666666666666,
                  0.3555555555555555,
                  0.4444444444444444,
                  0.3555555555555555,
                  0.6444444444444444,
                  0.4666666666666667,
                  0.5111111111111111,
                  0.3555555555555555,
                  0.4444444444444444,
                  0.4666666666666667,
                  0.5111111111111111,
                  0.8888888888888888,
                  1.111111111111111,
                  0.9777777777777776,
                  0.39998222301231057,
                  0.19997778024663923,
                  0.20000888928396818,
                  0.5333333333333332,
                  0.4889432159128792,
                  0.5333333333333333,
                  0.2444444444444444,
                  0.2666666666666666,
                  0.24444444444444444,
                  0.26666666666666666,
                  0.3555555555555555,
                  0.2666666666666666,
                  0.6888888888888888,
                  0.7333333333333333,
                  0.8222222222222221,
                  0.4666666666666667,
                  0.4444444444444444,
                  0.4888888888888889,
                  0.6222222222222221,
                  0.7555555555555555,
                  0.7333333333333332,
                  0.5333333333333332,
                  0.4444444444444444,
                  0.4888888888888888,
                  0.4666666666666667,
                  0.4888888888888889,
                  0.5555555555555554,
                  0.8444444444444443,
                  0.5999999999999999,
                  0.7777777777777777,
                  0.4888888888888889,
                  0.5555555555555554,
                  0.37777777777777777
        "refId": "B"
      "B-Instant": {
        "status": 200,
        "frames": [
            "schema": {
              "meta": {
                "typeVersion": [
                  0,
                  1
                "custom": {
                "notices": [
              "fields": [
                  "name": "Time",
                  "type": "time",
                  "typeInfo": {
                  "config": {
                    "interval": 15000
                  "name": "Value",
                  "type": "number",
                  "typeInfo": {
                    "frame": "float64"
                  "labels": {},
                  "config": {
            "data": {
              "values": [
                  1751436670386
                  0.46666666666666656
Not that I’m aware of.
No
Select (by clicking on the legend) only one “ghost” timeseries - there can be single datapoint - use query inspector to inspect query result.
And try to sum by agent_node label explicitly to fix the issue.
I tried to add the sum(agent_host) and it yields the same results, other than slightly changing the query names to the value of agent_host, which is the IP address of the monitored access point.
If I click on one of the “ghost” items in the chart itself, then both the “ghost” and the “real” items are selected in the chart. I bumped this down to a 5-minute time window, so the individual data points are more easily visible.
I’m still confused why the duplicate / ghost items are showing up here. :thinking:
Use range query only, not both (range+instant):
Thank you! That worked perfectly.
I also renamed each of the queries, so that the name is more “clean” in the legend. :slight_smile:
I appreciate your assistance!
