display data on the dashboard of a metric -
Using a query in grafana -
What happened?
The dashboard is empty -
display metric data -
sum(rate(ocpm_ingress_request_total{kubernetes_namespace=“$namespace”, kubernetes_pod_name=~“.diam.”}[2m]))
sum(rate(ocpm_ingress_request_total{kubernetes_namespace=“$namespace”, kubernetes_pod_name=~“.smservice.”}[2m])) -
No errors -
I have checked only the metric and the data is there, I have been adding the rest of the conditions and it is working. Apparently the problem is when I try to use the SUM(RATE) functions. when I combine them it does not show data.
I am using the same queries in other dashboards and they work correctly, of the 4 sites only one does not show data, I have exported/imported the dashboard but it still does not show data.
