Grafana11 on server 2012 r2 doesn’t run
    V11.1.0
    Try to install on windows Server 2012 R2
    intel Xeon CPU E3-1220v6 @3.00Ghz 8GB ram 64 bit Operating system
  • What happened?
    …reverse proxy setting
