Installation on Windows Server and Centos
I read the docs about the installation on windows and Centos but it didn’t specific the required version of the OS.
May anyone help me to confirm, please?
My major web server is IIS/Apache HTTP server on Windows Server 2008 R2 and Apache HTTP server on Centos 6 ; database is MySQL 5.1/5.5 database server.
Thank you.
We currently only have 64-bit builds on the download page but if your servers are 64-bit then Grafana should work.
It should work fine on any relatively modern version of Windows. Windows Server 2008 should work but I’m not sure - we have never tested that version.
You might have some problems with MySQL depending on which settings you use (authentication for example) - that is a very old version.
CentOS 6 should also work - it is still being updated.
I’ve been using Grafana on Windows 2012 R2, and it has been working fine. Just modify some basic configs and run unless you have a good reason to mess with IIS and MySQL. Grafana is PnP :smiley:.
