Grafana with Firefox 60 or IE 11
Hello
I’m trying to install and configure Grafana 6.7.2 on a windows machine (windows server 2012 R2 Standard) with Firefox Version 60.6.3esr (64-bit) and Internet Explorer 11. The version 6.7.2 of Grafana doesn’t seem to be compatible with these browser’s versions. But I can’t upgrade the browsers !
Which version of Grafana do you advise me to try Grafana with these 2 browsers ? I wan’t to test Grafana with data from elasticsearch 6.7.
Thank you
Hi!
Grafana is only supports IE11 in versions prior to v6.0. https://grafana.com/docs/grafana/latest/installation/requirements/#supported-web-browsers. You could try with 5.4.5.
/Tobias Skarhed
Hello, thank you Tobias J
Hello Tobias
We have installed version 5.4.5 of Grafana. It’s OK now with IE 11. Thank you.
