Any special considerations for a multi-version upgrade from 6 to 11?
Using Grafana OSS on Windows 2008r2. I now have Grafana 6.7.3. I’m looking at upgrading to V 11.0 OSS.
It is working fine, but I’m seeing the system hang when it attempts to shut down or restart and the shutdown of Grafana is the last thing in the system log before I have to force a restart with a power cycle:
Before I get into debugging this issue, I want to have the latest version.
Are there any tips or pointers I should keep in mind when upgrading from 6 to 11? I assume it can be done in one step? Above and beyond following the instructions here ?
These instructions for Windows say “In your current installation of Grafana, save your custom configuration changes to a file named <grafana_install_dir>/conf/custom.ini.”
My config folder C:\Program Files\GrafanaLabs\grafana\conf contains defaults.ini and sample.ini. There is no Custom.ini. It is unclear how to “save your custom configuration”
The instructions then say “Extract the contents of the Windows Binary package to the location in which you installed Grafana.” I assume it would be necessary to stop the service (path to c:\Program Files\GrafanaLabs\nssm.exe) from the Services manager before overwriting the binary files?
Background on shutdown hang: From System Log: (shutdown initiated at 3:49. Noticed failure and power cycled at 4:34.
Level	Date and Time	Source	Event ID	Task Category
Information	5/26/2024 4:34:36 PM	Microsoft-Windows-User Profiles Service	1531	None	"The User Profile Service has started successfully.
Information	5/26/2024 3:49:48 PM	nssm	1011	None	Killing process C:\Program Files\GrafanaLabs\grafana\bin\grafana-server.exe because service Grafana is stopping.
Information	5/26/2024 3:49:48 PM	nssm	1040	None	Service Grafana received SHUTDOWN control, which will be handled.
upgrade one full version at a time imo. dont jump from 6 to 11
go
6 to 7 test
7 to 8 test
8 to 9 test
9 to 10 test
10 to 11 test
Thanks for the reply.
To confirm, I download the Windows Binaries for versions 7 through 11. I pick the last of each major version series 7.5.17, 8.5.27, etc. (presumably the most stable?)
Since I do not have a custom.ini, there is no file that needs to be saved in the conf directory?
So the process is like this (in python pseudo code)
for x in range (7, 12):
    stop Grafana Service
    extract binaries for version x into "C:\Program Files\GrafanaLabs\grafana" and overwrite
    start Grafana service
    test Dashboard
In case of failure, extract prior version and then ???
I would not overwrite existing grafana folder. This is what I do personally
I have a folder in C drive named LGTM
I download the grafana zip file for windows and extract the zip file, copy pertinent folders from previous version to new version folder, run grafana-server.exe in bin folder in new version folder and verify all is working.
no files except the data folder where your plugins and grafana.db are if you are using sqllite as a backend for grafana.
we will cross that bridge when we get to it :wink:
I have a service that is set to automatic.
It runs C:\Program Files\GrafanaLabs\nssm.exe
So I would stop the service, create the folders for the multiple versions such as:
c:\temp\grafana-7-5-17
and extract grafana-7.5.17.windows-amd64.zip into that folder. Then copy the contents of C:\Program Files\GrafanaLabs\grafana\data (my current data) into the c:\temp\grafana-7-5-17 folder. Then run grafana-server.exe in c:\temp\grafana-7-5-17\bin folder
Iterate through versions, moving the \data folder to each new version’s folder
When all versions have been tested, copy the final test folder c:\temp\grafana-11-0-0 back to C:\Program Files\GrafanaLabs\grafana.
Then change the service back to automatic.
This process is rather complex and there is no mention of it on the Upgrade Grafana | Grafana documentation Thanks for sharing.
indeed it is. go ahead and upgrade 6 to 11. it might work
I tried copying the \data folder into the temp folder for V11 and running the server from that location. It doesn’t work.
C:\Temp\GrafanaTemp\grafana-v11.0.0\bin>grafana-server.exe
Exception 0xc0000005 0x8 0x0 0x0
PC=0x0
runtime.asmstdcall()
        runtime/sys_windows_amd64.s:65 +0x75 fp=0x22fca0 sp=0x22fc80 pc=0x465ab5
rax     0x0
rbx     0x5b3d60
rcx     0x6065c0
rdi     0x7fffffdd000
rsi     0x22fea0
rbp     0x22fde0
rsp     0x22fc78
r8      0x0
r9      0x22fee0
r10     0x5d8698
r11     0x21
r12     0x22fec0
r13     0x1
r14     0x5b3700
r15     0x0
rip     0x0
rflags  0x10293
cs      0x33
fs      0x53
gs      0x2b
I copied \data to the V7 folder, and ran grafana-server.exe from \bin
That worked.
Then I moved \data to the V8 folder and ran grafana-server.exe from \bin
That worked
Then I moved \data to the V9 folder and ran grafana-server.exe from \bin
That fails with an exception, same as V11
I noticed that when the server ran, it logged "Executing migration " so apparently migration is necessary, but the migration to V9 is problematic?
well you are migrating, so that is to be expected
did you stop the other grafana servers running on port 3000
Yes the prior server was always stopped. I had stopped the service before starting, and was running grafana-server.exe from the CLI as foreground, so I could not run the next version until I killed the prior one with ctrl-C.
Here’s the output from running from CLI after copying V8 files back to the normal execution location. C:\Program Files\GrafanaLabs\grafana
There are some errors but it does appear to work normally. (it looks like output is for ANSI terminal, not windows CMD)
C:\Program Files\GrafanaLabs\grafana\bin>grafana-server.exe
←[32mINFO ←[0m[06-01|12:55:04] Starting Grafana                         ←[32mlogger←[0m=settings ←[32mversion←[0m=8.5.27 ←[32mcommit←[0m=5f9e0ace7e ←[32mbranch←[0m=HEAD ←[32mcompil
ed←[0m=2023-06-07T05:18:00-0500
←[32mINFO ←[0m[06-01|12:55:04] The state of unified alerting is still not defined. The decision will be made during as we run the database migrations ←[32mlogger←[0m=settings
←[32mINFO ←[0m[06-01|12:55:04] Config loaded from                       ←[32mlogger←[0m=settings ←[32mfile←[0m="C:\\Program Files\\GrafanaLabs\\grafana/conf/defaults.ini"
←[32mINFO ←[0m[06-01|12:55:04] Path Home                                ←[32mlogger←[0m=settings ←[32mpath←[0m="C:\\Program Files\\GrafanaLabs\\grafana"
←[32mINFO ←[0m[06-01|12:55:04] Path Data                                ←[32mlogger←[0m=settings ←[32mpath←[0m="C:\\Program Files\\GrafanaLabs\\grafana\\data"
←[32mINFO ←[0m[06-01|12:55:04] Path Logs                                ←[32mlogger←[0m=settings ←[32mpath←[0m="C:\\Program Files\\GrafanaLabs\\grafana\\data\\log"
←[32mINFO ←[0m[06-01|12:55:04] Path Plugins                             ←[32mlogger←[0m=settings ←[32mpath←[0m="C:\\Program Files\\GrafanaLabs\\grafana\\data\\plugins"
←[32mINFO ←[0m[06-01|12:55:04] Path Provisioning                        ←[32mlogger←[0m=settings ←[32mpath←[0m="C:\\Program Files\\GrafanaLabs\\grafana\\conf\\provisioning"
←[32mINFO ←[0m[06-01|12:55:04] App mode production                      ←[32mlogger←[0m=settings
←[32mINFO ←[0m[06-01|12:55:04] Connecting to DB                         ←[32mlogger←[0m=sqlstore ←[32mdbtype←[0m=sqlite3
←[33mWARN ←[0m[06-01|12:55:04] SQLite database file has broader permissions than it should ←[33mlogger←[0m=sqlstore ←[33mpath←[0m="C:\\Program Files\\GrafanaLabs\\grafana\\data\\gr
afana.db" ←[33mmode←[0m=-rw-rw-rw- ←[33mexpected←[0m=-rw-r-----
←[32mINFO ←[0m[06-01|12:55:04] Starting DB migrations                   ←[32mlogger←[0m=migrator
←[32mINFO ←[0m[06-01|12:55:04] migrations completed                     ←[32mlogger←[0m=migrator ←[32mperformed←[0m=0 ←[32mskipped←[0m=392 ←[32mduration←[0m=1ms
←[33mWARN ←[0m[06-01|12:55:04] error loading storage                    ←[33mlogger←[0m=grafanaStorageLogger ←[33mprefix←[0m=public-static ←[33merr←[0m="open blob.Bucket: parse \"f
ile://C:\\\\Program Files\\\\GrafanaLabs\\\\grafana\\\\public\": invalid port \":\\\\Program Files\\\\GrafanaLabs\\\\grafana\\\\public\" after host"
←[31mEROR ←[0m[06-01|12:55:05] Could not start plugin                   ←[31mlogger←[0m=plugin.manager ←[31mpluginId←[0m=stackdriver ←[31merr←[0m="plugin stackdriver is already reg
istered"
←[32mINFO ←[0m[06-01|12:55:05] Query Service initialization             ←[32mlogger←[0m=query_data
←[32mINFO ←[0m[06-01|12:55:05] Live Push Gateway initialization         ←[32mlogger←[0m=live.push_http
←[32mINFO ←[0m[06-01|12:55:06] warming cache for startup                ←[32mlogger←[0m=ngalert
←[32mINFO ←[0m[06-01|12:55:06] starting MultiOrg Alertmanager           ←[32mlogger←[0m=ngalert.multiorg.alertmanager
←[32mINFO ←[0m[06-01|12:55:06] storage starting                         ←[32mlogger←[0m=grafanaStorageLogger
←[32mINFO ←[0m[06-01|12:55:06] HTTP Server Listen                       ←[32mlogger←[0m=http.server ←[32maddress←[0m=[::]:3000 ←[32mprotocol←[0m=http ←[32msubUrl←[0m= ←[32msocket←[
0m=
←[32mINFO ←[0m[06-01|12:55:50] Request Completed                        ←[32mlogger←[0m=context ←[32mtraceID←[0m=00000000000000000000000000000000 ←[32muserId←[0m=1 ←[32morgId←[0m=1
 ←[32muname←[0m=admin ←[32mmethod←[0m=GET ←[32mpath←[0m=/api/live/ws ←[32mstatus←[0m=0 ←[32mremote_addr←[0m=192.168.27.106 ←[32mtime_ms←[0m=6 ←[32mduration←[0m=6.0004ms ←[32msize←[
0m=0 ←[32mreferer←[0m= ←[32mtraceID←[0m=00000000000000000000000000000000
←[32mINFO ←[0m[06-01|12:55:50] Initialized channel handler              ←[32mlogger←[0m=live ←[32mchannel←[0m=grafana/dashboard/uid/jZ5Ky1RGk ←[32maddress←[0m=grafana/dashboard/uid
/jZ5Ky1RGk
←[32mINFO ←[0m[06-01|12:55:56] Request Completed                        ←[32mlogger←[0m=context ←[32mtraceID←[0m=00000000000000000000000000000000 ←[32muserId←[0m=1 ←[32morgId←[0m=1
 ←[32muname←[0m=admin ←[32mmethod←[0m=GET ←[32mpath←[0m=/api/live/ws ←[32mstatus←[0m=0 ←[32mremote_addr←[0m=192.168.27.106 ←[32mtime_ms←[0m=13 ←[32mduration←[0m=13.0007ms ←[32msize
←[0m=0 ←[32mreferer←[0m= ←[32mtraceID←[0m=00000000000000000000000000000000
←[32mINFO ←[0m[06-01|12:56:33] Shutdown started                         ←[32mlogger←[0m=server ←[32mreason←[0m="System signal: interrupt"
←[32mINFO ←[0m[06-01|12:56:33] Closing tracing                          ←[32mlogger←[0m=tracing
←[31mEROR ←[0m[06-01|12:56:33] context canceled                         ←[31mlogger←[0m=ngalert
what version is this target folder
I am now running grafana-8.5.27 I copied all the folders in the temp structure back to C:\Program Files\GrafanaLabs\grafana.
I tested it from C:\Program Files\GrafanaLabs\grafana\bin>grafana-server.exe which is the output in the prior message. Then I closed that CMD, and re-started the service.
It seems to be running fine with 8.5.27, but I’m unsure why V9 did not migrate also, or what steps to take next.
Maybe try smaller steps: 9.0, 9.1, etc up to 9.5.19.?
what version was in this above folder
I would say that newer Grafana binaries are built with newer Golang 1.21+, which doesn’t support your old Windows 2008r2 anymore (it is 4 years after end of extended support - why you are using it anyway :open_mouth: :rotating_light:).
As announced in the Go 1.20 release notes, Go 1.21 requires at least Windows 10 or Windows Server 2016; support for previous versions has been discontinued.
So if you need it, then build own Grafana binaries with Golang 1.20.14.
