Hello All,
After installing Grafana, the web page stays pending, with the loading icon continuously bouncing up and down. It has been like this for half an hour and still won’t load the login page.
Starting Logs:
logger=settings t=2025-07-01T07:29:19.680523634Z level=info msg="Starting Grafana" version=12.0.2 commit=5bda17e7c1cb313eb96266f2fdda73a6b35c3977 branch=HEAD compiled=2025-07-01T07:29:19Z
logger=settings t=2025-07-01T07:29:19.680978352Z level=info msg="Config loaded from" file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2025-07-01T07:29:19.681013724Z level=info msg="Config loaded from" file=/etc/grafana/grafana.ini
logger=settings t=2025-07-01T07:29:19.681028588Z level=info msg="Config overridden from command line" arg="default.paths.data=/var/lib/grafana"
logger=settings t=2025-07-01T07:29:19.681042693Z level=info msg="Config overridden from command line" arg="default.paths.logs=/var/log/grafana"
logger=settings t=2025-07-01T07:29:19.681058599Z level=info msg="Config overridden from command line" arg="default.paths.plugins=/var/lib/grafana/plugins"
logger=settings t=2025-07-01T07:29:19.681091337Z level=info msg="Config overridden from command line" arg="default.paths.provisioning=/etc/grafana/provisioning"
logger=settings t=2025-07-01T07:29:19.681106078Z level=info msg=Target target=[all]
logger=settings t=2025-07-01T07:29:19.681129439Z level=info msg="Path Home" path=/usr/share/grafana
logger=settings t=2025-07-01T07:29:19.681142148Z level=info msg="Path Data" path=/var/lib/grafana
logger=settings t=2025-07-01T07:29:19.681153876Z level=info msg="Path Logs" path=/var/log/grafana
logger=settings t=2025-07-01T07:29:19.681165753Z level=info msg="Path Plugins" path=/var/lib/grafana/plugins
logger=settings t=2025-07-01T07:29:19.68117773Z level=info msg="Path Provisioning" path=/etc/grafana/provisioning
logger=settings t=2025-07-01T07:29:19.681189897Z level=info msg="App mode production"
logger=featuremgmt t=2025-07-01T07:29:19.681578032Z level=info msg=FeatureToggles alertingSimplifiedRouting=true onPremToCloudMigrations=true preinstallAutoUpdate=true recoveryThreshold=true azureMonitorPrometheusExemplars=true tlsMemcached=true alertingRuleVersionHistoryRestore=true dashboardSceneForViewers=true logRowsPopoverMenu=true ssoSettingsSAML=true recordedQueriesMulti=true azureMonitorEnableUserAuth=true awsAsyncQueryCaching=true newDashboardSharingComponent=true angularDeprecationUI=true transformationsRedesign=true groupToNestedTableTransformation=true logsExploreTableVisualisation=true prometheusUsesCombobox=true pinNavItems=true formatString=true kubernetesClientDashboardsFolders=true alertRuleRestore=true addFieldFromCalculationStatFunctions=true correlations=true unifiedStorageSearchPermissionFiltering=true lokiLabelNamesQueryApi=true grafanaconThemes=true cloudWatchCrossAccountQuerying=true logsPanelControls=true logsContextDatasourceUi=true cloudWatchNewLabelParsing=true nestedFolders=true newFiltersUI=true dashboardSceneSolo=true dashgpt=true unifiedRequestLog=true annotationPermissionUpdate=true alertingRuleRecoverDeleted=true alertingQueryAndExpressionsStepMode=true alertingRulePermanentlyDelete=true lokiQueryHints=true reportingUseRawTimeRange=true ssoSettingsApi=true alertingApiServer=true alertingUIOptimizeReducer=true failWrongDSUID=true alertingNotificationsStepMode=true newPDFRendering=true lokiStructuredMetadata=true useSessionStorageForRedirection=true alertingInsights=true kubernetesPlaylists=true publicDashboardsScene=true dataplaneFrontendFallback=true prometheusAzureOverrideAudience=true pluginsDetailsRightPanel=true cloudWatchRoundUpEndTime=true externalCorePlugins=true promQLScope=true panelMonitoring=true lokiQuerySplitting=true logsInfiniteScrolling=true influxdbBackendMigration=true dashboardScene=true
logger=sqlstore t=2025-07-01T07:29:19.681669812Z level=info msg="Connecting to DB" dbtype=sqlite3
logger=migrator t=2025-07-01T07:29:19.691020041Z level=info msg="Locking database"
logger=migrator t=2025-07-01T07:29:19.691060141Z level=info msg="Starting DB migrations"
logger=migrator t=2025-07-01T07:29:19.710572362Z level=info msg="migrations completed" performed=0 skipped=768 duration=854.066µs
logger=migrator t=2025-07-01T07:29:19.711092097Z level=info msg="Unlocking database"
logger=licensing t=2025-07-01T07:29:19.711616382Z level=info msg="Validated license token" appURL=http://localhost:3000/ source=disk status=NotFound
logger=secrets t=2025-07-01T07:29:19.711669144Z level=info msg="Envelope encryption state" enabled=true currentprovider=secretKey.v1
logger=plugin.angulardetectorsprovider.dynamic t=2025-07-01T07:29:19.796956624Z level=info msg="Restored cache from database" duration=467.157µs
logger=resource-migrator t=2025-07-01T07:29:19.806150089Z level=info msg="Locking database"
logger=resource-migrator t=2025-07-01T07:29:19.806189521Z level=info msg="Starting DB migrations"
logger=resource-migrator t=2025-07-01T07:29:19.814872096Z level=info msg="migrations completed" performed=0 skipped=26 duration=46.487µs
logger=resource-migrator t=2025-07-01T07:29:19.815359643Z level=info msg="Unlocking database"
t=2025-07-01T07:29:19.815550107Z level=info caller=logger.go:214 time=2025-07-01T07:29:19.815535985Z msg="Using channel notifier" logger=sql-resource-server
logger=plugin.store t=2025-07-01T07:29:19.81640773Z level=info msg="Loading plugins..."
logger=plugins.registration t=2025-07-01T07:29:19.842106168Z level=error msg="Could not register plugin" pluginId=table error="plugin table is already registered"
logger=plugins.initialization t=2025-07-01T07:29:19.842150467Z level=error msg="Could not initialize plugin" pluginId=table error="plugin table is already registered"
logger=plugins.registration t=2025-07-01T07:29:19.885037735Z level=info msg="Plugin registered" pluginId=grafana-exploretraces-app
logger=plugins.registration t=2025-07-01T07:29:19.944708947Z level=info msg="Plugin registered" pluginId=grafana-lokiexplore-app
logger=plugins.registration t=2025-07-01T07:29:19.98400583Z level=info msg="Plugin registered" pluginId=grafana-metricsdrilldown-app
logger=plugins.registration t=2025-07-01T07:29:20.015344701Z level=info msg="Plugin registered" pluginId=grafana-pyroscope-app
logger=plugin.store t=2025-07-01T07:29:20.015386187Z level=info msg="Plugins loaded" count=57 duration=198.979698ms
logger=caching.service t=2025-07-01T07:29:20.016855553Z level=info msg="Caching service is disabled"
logger=query_data t=2025-07-01T07:29:20.020279318Z level=info msg="Query Service initialization"
logger=live.push_http t=2025-07-01T07:29:20.02443497Z level=info msg="Live Push Gateway initialization"
logger=ngalert.notifier.alertmanager org=1 t=2025-07-01T07:29:20.028833043Z level=info msg="Applying new configuration to Alertmanager" configHash=d2c56faca6af2a5772ff4253222f7386
logger=ngalert t=2025-07-01T07:29:20.043542545Z level=info msg="Using simple database alert instance store"
logger=ngalert.state.manager.persist t=2025-07-01T07:29:20.043582982Z level=info msg="Using sync state persister"
logger=infra.usagestats.collector t=2025-07-01T07:29:20.047232196Z level=info msg="registering usage stat providers" usageStatsProvidersLen=3
logger=server t=2025-07-01T07:29:20.047317976Z level=info msg="Writing PID file" path=/run/grafana/grafana-server.pid pid=46689
logger=grafanaStorageLogger t=2025-07-01T07:29:20.04767746Z level=info msg="Storage starting"
logger=ngalert.state.manager t=2025-07-01T07:29:20.047704714Z level=info msg="Warming state cache for startup"
logger=provisioning.alerting t=2025-07-01T07:29:20.049275856Z level=info msg="starting to provision alerting"
logger=provisioning.alerting t=2025-07-01T07:29:20.049324462Z level=info msg="finished to provision alerting"
logger=http.server t=2025-07-01T07:29:20.051161031Z level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
logger=report t=2025-07-01T07:29:20.052241524Z level=warn msg="Scheduling and sending of reports disabled, SMTP is not configured and enabled. Configure SMTP to enable."
logger=ngalert.multiorg.alertmanager t=2025-07-01T07:29:20.05241871Z level=info msg="Starting MultiOrg Alertmanager"
logger=provisioning.dashboard t=2025-07-01T07:29:20.084614855Z level=info msg="starting to provision dashboards"
logger=provisioning.dashboard t=2025-07-01T07:29:20.084663436Z level=info msg="finished to provision dashboards"
logger=ngalert.state.manager t=2025-07-01T07:29:20.084945966Z level=info msg="State cache has been initialized" states=0 duration=37.240554ms
logger=ngalert.scheduler t=2025-07-01T07:29:20.08501311Z level=info msg="Starting scheduler" tickInterval=10s maxAttempts=3
logger=ticker t=2025-07-01T07:29:20.085094863Z level=info msg=starting first_tick=2025-07-01T07:29:30Z
logger=plugins.update.checker t=2025-07-01T07:29:20.709708225Z level=info msg="Update check succeeded" duration=657.775096ms
logger=grafana.update.checker t=2025-07-01T07:29:20.759930037Z level=info msg="Update check succeeded" duration=712.216217ms
logger=grafana-apiserver t=2025-07-01T07:29:20.932512288Z level=info msg="Adding GroupVersion notifications.alerting.grafana.app v0alpha1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.933259218Z level=info msg="Adding GroupVersion reporting.grafana.app v0alpha1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.933946049Z level=info msg="Adding GroupVersion playlist.grafana.app v0alpha1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.93446363Z level=info msg="Adding GroupVersion featuretoggle.grafana.app v0alpha1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.935185572Z level=info msg="Adding GroupVersion userstorage.grafana.app v0alpha1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.938026016Z level=info msg="Adding GroupVersion dashboard.grafana.app v1beta1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.938583737Z level=info msg="Adding GroupVersion dashboard.grafana.app v0alpha1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.939080146Z level=info msg="Adding GroupVersion dashboard.grafana.app v2alpha1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.939914778Z level=info msg="Adding GroupVersion folder.grafana.app v1beta1 to ResourceManager"
logger=grafana-apiserver t=2025-07-01T07:29:20.941197071Z level=info msg="Adding GroupVersion iam.grafana.app v0alpha1 to ResourceManager"
logger=app-registry t=2025-07-01T07:29:20.988516544Z level=info msg="app registry initialized"
logger=infra.usagestats t=2025-07-01T07:30:23.05163104Z level=info msg="Usage stats are ready to report"
logger=cleanup t=2025-07-01T07:39:20.050967426Z level=info msg="Completed cleanup jobs" duration=2.568088ms
logger=plugins.update.checker t=2025-07-01T07:39:21.381954602Z level=info msg="Update check succeeded" duration=671.946763ms
