Grafana trino plugin can not work
hi,
I have config a trino datasource as below pic.
but when i submit a query with trino connection as below.
I can’t get the data. I try to use trino console to check the sql ,that is correct.
so i don’t know if i have some mistake for my configure.
Could you help me to figure out.
THANK YOU!! the grafana team
“I was having issues using plugin 1.0.5; when I downgraded to 1.0.4, the plugin worked correctly.”
plugins:
   - trino-datasource 1.0.4
Thanks for your reply, i also use 1.0.4, It has worked.
