Grafana Datasource 'unexpected error happened'
Hello everyone, a few days ago I started having this error in Grafana…
I use the oss version in docker with the plugins installed via compose, regardless of the version, I have this problem.
I would like to know if there is any solution.
The last image I noticed with this problem
grafana/grafana-oss:10.0.0-ubuntu.
May be this is the case:
Hello, thank you for your attention, the version of Grafana I am using is 10.0.0 (OSS) I have also tried with 11.0.0 (OSS) but the error persists.
Hey @eliassparda :wave:
Thanks a lot for raising attention, we are having a look!
Seems like there’s also a github issue for the same problem, probably worth keeping an eye on that as well for future updates: Data sources page does not load with plugin 4.6.0 and Grafana version < 10.2.3 · Issue #1939 · grafana/grafana-zabbix · GitHub
