I’m trying to create a custom datasource plugin in Grafana v8.0.3, but keep getting: Fetch error: 404 Not Found Instantiating http://grafana.staged-by-discourse.com/grafana/public/plugins/test-my-plugin/module.js Loading plugins/test-my-plugin/module
However, the same plugin works for Grafana v7.5.3. I’m following this link: Build a data source plugin | Grafana Labs
I’m using Docker to host Grafana: docker run -d -p 3000:3000 -v C:\dev\grafana\grafana-plugins:/var/lib/grafana/plugins -v C:\dev\grafana\config\grafana.ini:/etc/grafana/grafana.ini --name=grafana grafana/grafana:8.0.3
Are there some additional steps that need to be executed when building your own datasource plugin for Grafana v8.0.3?
