Grafana OSS 10.0.3 BUG
Hello, I use Grafana OSS 10.0.2, on my local machine, (localhost). I also use Grafana Cloud over the web. In these two places my data (InfluxDB and MQTT plugin) are appearing normally. I also use Grafana on an EC2 instance running Ubuntu Server on AWS. After upgrading Grafana on EC2 on AWS from version 10.0.2 to version 10.0.3, Grafana connects to my two data sources (InfluxDB and MQTT plugin), but does not show the data. Does anyone know what could be happening? Does anyone know if this is a Grafana OSS 10.0.3 bug?
Hi @k2xttechnology,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
So If I understand correctly that the Grafana on EC2 uses those data sources which you have configured locally? and before update it always worked but now the Dashboard appears blank (or maybe a error message)?
The problem is only on MQTT plugin in Grafana OSS 10.0.3. InfluxDB is working now.
I had a problem with Telegraf, that’s why the InfluxDB data wasn’t showing up.
Usman Ahmad, I have two INfluxDB databases, one on my local machine (localhost) and the other in the cloud (EC2 Instance AWS).
Usman Ahmad Thank you for your help. The problem in the MQTT Plugin continues. I’m going to try to downgrade to Grafana OSS 10.0.2.
Hi All,
I’ve noticed an error, it seems to be a bug, on Polystat, I’m getting randomly an error Cannot read properties of undefined (reading 'color')
Thanks in advance for your feedback
More details about the reporting bug, it appears when the mouse pointer moves over other Polystats that have more than one element (for my case)
react-dom.production.min.js:189 TypeError: Cannot read properties of undefined (reading 'color')
    at Et (Tooltip.tsx:164:39)
    at Ru (react-dom.production.min.js:167:137)
    at ml (react-dom.production.min.js:197:258)
    at sv (react-dom.production.min.js:292:88)
    at $v (react-dom.production.min.js:280:389)
    at vh (react-dom.production.min.js:280:320)
    at Th (react-dom.production.min.js:280:180)
    at _v (react-dom.production.min.js:271:88)
    at Uv (react-dom.production.min.js:268:429)
    at B (scheduler.production.min.js:13:203)
Thanks
Hi @hsiahmed,
We would appreciate it if you can open a bug report about this in our official GitHub repository using this link.
Provide all the information (you can simply copy/paste your data + screenshot from here to there).
Lastly, paste the link to your GitHub issue here in this post so that all other community users can also track it. I will also add more additional information to it :+1:
